I currently had the primary feeder of a 225-kVA delta-wye transformer metered. The metering report indicates 480-volts at all three of the phase measurements (L1-L2, L2-L3, L3-L1) but indicates amp readings at only two of the phase measurements (L1-L2 and L3-L1). The amp readings at
L2-L3 were reported as zero amps.
Does this seem correct?
Additionally, is the overall measured load (amps) for this system just determined by adding together the recorded values that were present at the L1-L2 and L3-L1 readings?
Something doesn't seem correct here but I may just be second guessing myself.
