Interpretation of NEC 2011: 210.12 (B)
h1h2h3
MA
Hey Guys,
Wanted your opinion on the following scenario.
I'm A MA licensed electrician working in a metropolitan area of MA. I change out all devices in a ten unit apt building. During the inspection, the inspector asks me why I didnt change the breakers to AFCI combo's. I reply that I didn't because I'm not required to under 210. 12 (B). He says thats the exact section that requires me to do so. I don't understand. I think he's wrong. I only changed out the devices I did not "modify, replace, or extend the branch ckt wiring." This is crazy (I think). Does that mean that everywhere (AFCI is required), every time i replace a $2.00 rec I need to replace a breaker that will cost me $50.00.
I think this article leaves too much room to let the AHJ interpret it however they'd like. Shouldn't the NEC then provide definitions for "modified wiring" and "extended wiring" ?
Lastly, do you think this is where the controversy over whether or not AFCI must be provided for existing circuits when a service is upgraded comes from? Murphy's Law guarantees that your existing wiring will never make your new panel. If I trough or can the wires, have i extended and modified the branch circuits? Im unclear on this and would appreciate some input/ clarification.
Thanks Guys
Personally I think the inspector is incorrect but the wording could easily lead someone to believe that you modified the circuit. If you look at the proposals for 2014 it may help the inspector to see that it is not the intent of the NEC to req. afci when changing a receptacle. It may be worth reading this thread.
You could also gently remind the inspector about this from the MA rules
I did remind him of rule 3 (gently posed it a question...lol). FYI rule 3 is every Mass electricians favorite amendment. Funny, he sort of caulked his head and raised his eyebrows and stated "You need the breakers." If i can convince the customer that its a good idea, no harm no foul...Ill give him all the afci's he wants. But if they wont go for it, I may have to stand my ground so I don't lose my shirt. Something which I am always apprehensive about doing. Definite risk/reward debate here.
I am going to print that thread out however and bring it to his attention. I really appreciate the advise guys.
