Re: interpreting the NEC
To understand the code and interpret it is a lifelong journey!! A few baby steps I would suggest are start at the beginning and study articles 90 and 100. Do not read them, disect them and slow down. Use the handbook for insight on what the text is really talking about, try to relate it to your everyday work, read this forum for more insight, and then start to LISTEN to your journeyman, your inspector, etc to figure out who you know would be a good mentor. Is that person knowledgable or opinionated, is his opinion based on fact, the NEC, or that is the whay he was taught, can he communicate his knowledge to you, etc. Select a mentor wisely and use him often.
When studying the code, article 100 is the most important because if you don't understand what a word actually means in the text you will never be able to grasp that particular section. The simplest example of that is the difference between outlet and receptacle in the code and in the field.
Good luck, use you patience and persistance, and don't be afraid in making a mistake as that is the most effective way of learning.
Fred Bender
