mooreaaryan
- Bakersfield CA
- Electrician
I have new construction project and just received IFC's and started construction Monday.
The prints show
1-400 amp Switchboard Supplied by utilities feeding our main
1-Main 400amp going to a distribution block then out of the distribution block
4- Pump Panel disconnects
1- Mini load center
1-Compressor Motor Disconnect panel
1-Cooler Motor Disconnect panel
1- Oil Make up Disconnect Panel
1-air compressor disconnect
1-water chiller disconnect
This would total 10 separate disconnecting means after the main
I believe this violates the MAX Number of Disconnects, or Am i misunderstanding the definitions of disconnecting means
The prints show
1- Mini load center
