ProjectDelta
- Michigan
- Electrician
I’m currently working on a paint booth project and am trying to understand some of the concepts behind the installation. We have several intrinsically safe circuits running to different instruments within the booth. The circuit runs from inside the booth, through a seal off to the clean room (unclassified location, and into a cable tray with several other circuits both IS and otherwise. It then comes to an enclosure where the barrier is located. My question is:
Is the circuit considered “intrinsically safe” through it’s entire length from the instrument to the barrier?
If it is not, at what point is the circuit no longer defined as intrinsically safe? The reason I ask is because I want to know if the requirements of separation apply and at what points do they apply. My thought is that a short circuit or ground fault that occurs outside of the class I division I location would not cause a spark. Therefore, a circuit would not need to be considered IS. Hoping someone can help clarify this concept for me as I’ve only been in the trade 3 years. TIA
