Folks,
I have read many of the posts here on installation in C1 D2 areas. It seems beat to death still, I am a bit confused.
Scenario
I have a pressure reactor in a C1-D2 area. The reactor system is down for extended maintenance and want to make some changes in the process instruments.
I want to install a 24v pressure transducer 4-20 output and wire it to a PLC (the plc and Hmi are in a non-classified area)
I have transducers in stock that are not rated. I generally wire these to two conductor shielded cable in non classified areas
Can these transducers be used? If so what are the isolation requirements between the areas?
If I get IS transducers does anything change re barrier requirements conduit sealing etc?
Scenario
