Chavo619
- United States
I have a exterior pole mounted with two fixtures, one normal, the other fed from an inverter circuit, both the normal fixture and the inverter are fed from the same normal panel. The inverter circuit/pole is part of the emergency egress exterior lighting, do the inverter circuits to the pole have to be on a separate conduit system?
