dgwahlquist
- Escondido, CA, USA
Can an inverter output circuit be run in an existing conduit with a non-PV circuit?
The PV system is using micro inverters. The PV string is located on the house roof and the inverter output circuit will run to a sub-panel located in the basement, which is fed from the main panel located at a detached garage. The most viable way of getting the PV string circuit into the basement is to run it through the same conduit which contains the feeder circuit for the house sub-panel. It's not clear to me if NEC 690.4 restricts me from doing that. Thanks.
