I'm looking at grid-interactive micro-inverters for PV applications; these are grid-tied inverters of about 200W that generate power from a PV panel. Specifically I was look at this datasheet: http://www.petrasolar.com/downloads/SunWave-AC-Module.pdf . What caught my eye is that it specifically lists both max Watts and max VARs, yet shows a power factor of >0.99. I haven't seen VARs listed on micro-inverter data sheets previously. This generated the following hypothetical question:
Assume the inverter operates in two modes: 1) near unity PF and max watts (VA=Watts), OR, 2) near zero PF and max VARs (VA=VARs). I think there wouldn?t be a demand penalty since VA doesn?t exceed Watts or VARs. Is this kind of behavior by a device OK from a utility perspective?
Thanks for comments.
