heaterdesigner
Hello
I am working on a project that requires (4) 2KW IR heaters be controlled. We are at the point to select how to feed the system and at what voltage, phasing. We would like to run the system at 230Vac 3-phase.
The heaters are all rated 2KW @ 230Vac. Because there are 4 heaters we are not sure how to wire them to take advantage of 3-phase. There is an additional fly in the ointment that the heaters need to be bank selectable in banks of 2, 3, or all 4 at a time. Currently it was laid out as 4 heaters in parallel. This will not take advantage of the 3-phase system because they are parallel across 1 phase of 230V.
Any suggestions or thoughts?
