Natfuelbilll
Hello -
I am involved in a new build project that specifies IR testing of the gear. The manufacturer did not install IR windows and they have work policy that forbid them from opening energized gear.
My question is if the industry has used an approach to perform IR testing as follows:
- The load should be operated at full load for three hours, or until the breaker reaches normal load temperature;
- Deenergize the system;
- Open equipment doors to expose previously energized gear quickly enough to limit temperature degradation;
- scan the breaker with an IR type non-contact thermometer and record the readings.
- Reenergize the system if no significant problems are present
