adagys
- SW of Chicago
I have a 1 1/2 hp single phase motor which is going to be used to supply water out of a prone for a lawn sprinkler system. It is approx 225 feet from the main panel. I
The folate on the motor says it draws 19.9/9.95. What size wire should I use and what size breaker? I'm concerned about voltage drop. Also, is a gfi breaker needed? I am planning on running it at 240 v. Thanks!!!
