A Amodedude1 New User Location N/A Occupation N/A Apr 3, 2023 #1 1 Can I use 10/3 wire (<60ft) on a 40amp breaker that is powering a 220V MXZ-5C42NA2 heat pump condenser? The manual says the min current draw is 31.9amps and recommend fuse size is 40amp. I Have 10/4 cable.
tom baker First Chief Moderator & NEC Expert Staff member Location Bremerton, Washington Occupation Master Electrician Apr 3, 2023 #2 You have no occupation on your profile and this appears to be a DIY post which we do not allow
