Is it just me or this the most poorly thought out and worded 250 requirement?
250.53 A 1
Below Permanent Moisture Level.
If practicable, rod, pipe, and plate electrodes
shall be embedded below permanent moisture level.
Rod, pipe, and plate electrodes shall be free from
nonconductive coatings such as paint or enamel.
At first glance you might think it is black and white clear. Many years ago I thought at first it means the rod or pipe needs to be completely buried into moist soil, or even blow the frost line if any. But then one starts to think about places like Arizona, New Mexico, Nevada and other like areas where there is no soil moisture and might not even really be soil like Lost Wages NV that is more or less gravel and granite rubble. What condition would have to be met as to not fully bury the rod if practical. If Practical & Shall Be do not jive. Couldn't I just use a 10 foot rod and leave a foot sticking up and damn the torpedoes?
The way out of it in my opinion is not to use rod or pipes if conditions cannot be met, but that can get expensive and time consuming.
Guess i am getting nick picky in my ole age. What are your two-cents worth?
250.53 A 1
