"Interaction with equipment" is something that determines when you must wear arc flash PPE, not necessarily use an EEWP. There are many tasks that may require arc flash PPE but not require a work permit. A EEWP is required only when doing "Energized work" per the 70E definition.
Of course, your plant may say otherwise and have more stringient EEWP requirements than the 70E requires.
