Bjenks
- East Coast of FL
I have an architect who is designing a multi-dwelling unit with no switch receptacle outlets per nec 210.70 and except for the hallways and bathrooms every room has a ceiling junction box on a switch. I see the definition of a Lighting Outlet is intended for the direct connection of a lamp holder or luminaire. So I should assume that you really don't need to connect a light fixture or fan to it for 210.70 compliance? As long as there is a junction box with a switched conductor going to it they are fine? I feel like I am defeating the purpose of the code as a switch receptacle is an easy lamp connection while a junction box would/should require an electrician to install.
When a person rents this dwelling unit, it seems that you won't be able to see in any room without a flashlight. But maybe I am just being too much of an engineer on it.
