On a set of plans, the engineer shows legally required standby power (NEC 701 not NEC 700 for emergency systems). The main service conductors are “tapped” ahead of the service disconnect and terminate in a separate service disconnect per NEC 701.12 (G). I argued the need for a transfer switch but cannot find a specific requirement. The engineer said a transfer switch is not required. After reflection, I agreed that if NEC 701.12 (G) is used to provide legally required standby power, a transfer switch accomplishes nothing. In truth, I have seen this type of install before. My question: is a transfer switch required (give code reference).
Thanks!
Thanks!
