When I'm installing my additional array ground per 690.47(D) in the 2014 code is this required to be irreversibly spliced all the way from the array to the ground rod?
We have been irreversibly crimping this #6 Bare additional array ground onto our racking & module equipment ground using a Brundy C-crimp, but this is expensive. I'm not seeing anything in the code that says this has to be irreversibly spliced, could we be using a split bolt for this connection instead of the C-crimp?
