I have an application involving a Class 1 Div 2 Group C,D area. The primary PLC control system will be located in a non-hazardous control room in an enclosure. This enclosure will also contain the I/O modules. The I/O modules are AB Flex I/O and the supplier states that they are rated for Class 1 Div 2 locations. Although they have this rating, will IS Barriers be required to interface the Flex I/O modules with the field instruments that are located outside of the non-hazardous area and within the designated Class 1 Div 2 Group C, D area? Even though the I/O modules are rated for Class 1 Div 2, I believe that IS Barriers are still required.
