I have a situation where the source is 120/240 and the load is about 600 feet away. I was considering stepping the voltage up to 480 and then dropping it down to 120/240 at the load. The real queston is it legal to pull the two 480 legs in PVC, Bond the transformer with one ground rod at the load and the neutral with another establishing a isolated system. The load is 200A at 120/240 so one can see the root of the question due to voltage drop and wire size. (Given seperation of the Ground rods) Normally I would say the neutral would have to be pulled thru at the sizing for the unbalanced load and the ground would have to be contigious.
