kevinware
- Louisville, KY
I have been asked by a member of management in the building I work if I would install some receptacles in his basement. Now the catch is that these receptacles will be used for audio equipment. (Amplifiers, mixers and the like)
I have not seen the basement yet but just thinking here, this equipment is probably expensive. This isn't a professional studio or anything so I can't see a need for any type of balanced power system and if I am reading 647.3 correctly I am not permitted to install this type of system in a single family residence, please correct me if I am misinterpreting 647.3. The way I was thinking of handling this is I was going to install each duplex receptacle on a dedicated circuit and have the owner invest in some sort of power conditioning unit. I am thinking of Romex as the wiring method but I may need to use some EMT and mounted some of these receptacles to the concrete foundation wall 334.15(B), like I said I'm not sure yet. Will see the basement tomorrow. Anyway, Would it be a better ideal to have these circuits be an isolated ground type? If I am bonding the standard receptacle to the metal box on a dedicated circuit is it still possible to have noise on the EGC? What are your opinions?
Thanks,
Kevin
Thanks,
Kevin
