Here is the scenario. A 400 Amp service with meter can outside and panel directly back to back. There is a 1/2 inch copper water line on the outside about 12' away. On the inside there is an 1-1/4" galvanized water main about 12' away from the panel. I want to run my 1/0 CU Grounding Electrode Conductor straight down out of the meter can to the ground rod. Then on the inside I want to run the water bond to the 1-1/4 water main from the panel. The question is, what size wire should be used to bond the water system? There seems be a disagreement about this among people I know. Personally I think it should be considered an equipment ground based upon the 400 amp Main Breaker, which would be #3 CU in this case, but others tell me it should be 1/0 CU like the Grounding Electrode Conductor, based upon the size of the 400 MCM Service conductors.
Would appreciate anyone's thoughts on this.
Thanks
Thanks
