gary
- California
- Retired electrical contractor / general contractor
A box has been built below this surface mounted 100 A service to enclose circuit conductors that run down the wall to a crawlspace. A few additional circuits enter the back of the box through the wood siding. There is a 3' wide eve at the top of this 8' wall but I imagine this service is exposed to driving rain from time to time. The back of the panel does not appear to be caulked to the wall to prevent water entry.
[/IMG]
This house is wired with Romex cable, but all of the original homeruns were sleeved with 1/2" flexible steel conduit up to the first outlet box. I have never seen anything like this before. I've been asked to upgrade the service to 200 amps. The simplest way to do that would be to shorten the soffit by whatever amount is necessary to accommodate the new panel and hook everything back up more or less the way it is now except that I would use a OH only panel designed to allow circuit entry across the entire bottom of the can. There is a stud bay directly behind this old panel and although it would be a little more difficult I think this whole mess should be replaced with a new semi-flush panel. What would you do?
[/IMG]
Someone ran Carflex under the house with a set of #6 CU conductors with the apparent intension of installing a spa, but then found there was no access to the panel.
[/IMG]
[/IMG]
