jmk396
- Pennsylvania
- Software Engineer
I've moved into a house with existing wiring in the basement and some wires are run under the floor joists which I believe is against code?
Is this allowed in this situation because of the HVAC ducts and other pipes? I'm asking because I need to run another outlet and was going to drill holes through the joists but I noticed this existing wire so I thought maybe I could run the second parallel to the first.
