jtracy
- New Hampshire
- Low votlage
Is it permitted to install an outlet above a drop ceiling grid in a commercial or residential occupancy?
			You can install one but you can only use it for temporary use.Is it permitted to install an outlet above a drop ceiling grid in a commercial or residential occupancy?
That's what I was thinking.A receptacle might be required by 210.63(A)...
Yes I should have mentioned that in my prior post. This is another really dumb code rule.Can't a wall-wart LV supply with no 120v wire be plugged in?
What’s an HRV?Just as a practical matter, and I know this doesn't have any basis in the NEC, but in Seattle we often have cord and plug HRV's above drop ceilings, and the inspectors allow us to put that split loom wire covering stuff over the cord.
AHJ at one of our offices also turned a semi-blind eye in this manner for our WiFi access points. The issue was later mooted by switching to PoE equipment.and the inspectors allow us to put that split loom wire covering stuff over the cord.
Heat recovery ventilatorWhat’s an HRV?
Anyway, that’s a double whammy. Plug in a receptacle above ceiling and covering a flexible cord.
-Hal
This situation comes up all the time when installing TVs on walls. You can’t drop the line cord down the wall or fish an extension cord up to it. They make a kit with a receptacle and box, a length of NM and another box with an inlet. Install the receptacle behind the TV and the inlet near an existing receptacle. Connect with a short extension cord.Does anyone manufacture a cable product that is dual rated as both an article 400 flexible cord and an article 300 wiring method? Would such a dual rated cable be allowed concealed in a wall or behind a dropped ceiling?
