Lbartowski
- MN
I work for a "design-build" contractor, which I've found means the engineering decisions get put on me (electrician not an engineer). Yes, technically we have a PE who signs our drawings, but he's not always available or capable, when it comes to what I encounter.
Anyway, I'm working on a 9-story multi-unit housing facility (old folks home). I need a switch in the main switchboard for a new 200 amp ERU on the roof, but there are no spares. One potential option is to disconnect the 30 year old capacitor (400 amp switch), fuse it down, and use it for the new mechanical equipment.
Do you see any reason why this capacitor would be necessary? Do capacitors, over time, lose their ability to function? My experience is that large capacitors are used in industrial facilities for PF correction due to extensive motor use, but this is an "old folks" home that doesn't have a lot of motors.
I wonder if it has something to do with the 50HP fire pump? The owner doesn't have a clue, and likely doesn't even know what they have, and so looking to them for direction, doesn't work.
I don't have a problem with telling them that their service is not sufficient, I just need to make sure that I know what I'm talking about.
Thanks for the help.
