Machiavelli999
I am wondering if a grounding electrode conductor is needed to be tied into the output ground bus bar of a UPS system. This Mike Holt page (http://www.mikeholt.com/technical.p...tems&type=u&title=Separately Derived Systems [Transformers,%20Generators,%20etc.]%20%284-10-2K%29)
says the following:
"A separately derived system derives its power from a transformer, generator, converter winding, batteries (UPS), or from a solar photovoltaic system."
But it also states,
"Other Systems - Generator, converter winding, UPS systems, or power from solar photovoltaic system are only considered to be a separately derived system, when the grounded (neutral) conductor in the transfer switch is switched"
The output of my UPS is not fed into a transfer switch, so I am wondering whether or not I need a grounding electrode conductor.
says the following:
But it also states,
