Is the next combination safe or I risk to burn/fry some equipment?
Hello everyone first of all. Thank you in advance for each kind answer I shall get.
1. Short story
Saturday I decided to test some solar panels. Since in my country most of the portable solar panels will not be delivered by amazon.com, from what can be delivered i decided to buy Instapark® 10 Watt Solar Panel Portable Solar Charger with Dual USB Ports for iPhone, iPad & all other USB Compatible Devices - http://www.amazon.com/Instapark®-Po...8&qid=1464094653&sr=8-1&keywords=instapark+10
Looking at instapark.com official technical specs of the product it sais:
Power output: 5V Standard USB port x 2
Maximum output current: 2 amp
I was wondering if I can pair it with an Anker PowerCore 15600 - https://www.anker.com/products/A1252011
Looking at official technical specs of the product it sais:
Input :5V / 2A
Output :5V / 4.8A
I would also like to pair the Anker PowerCore 15600 with KingMa USB dual LP-E8 charger for Canon EOS 700D - which has apparently the next technical data:
Input: 5V 2000mA
2. The questions... and thank you again in advance for any usefull answer I will get.
- Can I charge Anker PowerCore 15600 with Instapark® 10 Watt Solar Panel safely? without burning anything I mean. I know Instapark 10 delivers maximum 2amps, but it can be less sometimes.
- Can I also charge a Canon batery using the KingMa USB LP-E8 safely with Anker PowerCore 15600? I see from the technical data Anker PowerCore delivers 4.8 amps, and KingMa only needs 2 amps.
Thank you kindly :)
Daniel
I am closing this thread in accordance with forum rules. This forum is intended to assist electricians, electrical contractors, inspectors, engineers, and other members of the electrical profession with their job related duties. If you are not an electrician, we are not permitted to help you perform your own electrical troubleshooting, installation, or maintenance work.
