618electrician
- St. Louis
- Maintenance electrician
other than normal wear is a federal main breaker safe ????????????????????????????????????????????????????????????????????????????????????????????
Can i replace the breakers with connecticut breakers would that make it safe ?FP Stab-Lok breakers are the specific ones to look out for. If the word Stab-Lok is on any part of the panel, replace the panel and the guts or wait for the place to burn down.
If the main is Stab-Lok, replace it. It is NOT safe.
That does not get rid of the problem with the bus connection.Can i replace the breakers with connecticut breakers would that make it safe ?
WHAT problem the new breakers fit tight !That does not get rid of the problem with the bus connection.
Why not change the panel?
