Is there a "rule of thumb" for going to a 480V service instead of a 208V?
bbaumer
Indiana
Is there a "rule of thumb" for say building size for commercial or educational type occupancies where it probably makes sense to go to a 480/277V service instead of a 208/120V service?
Not looking for a detailed analysis just looking for a guideline that says "air conditioned office buildings greater than X square feet are worth it to go to 480/277V".
The thinking is the savings on copper, # breakers, number of lighting circuits, I2R losses, bus sizes etc. more than offset the cost of the dry transformer and higher voltage rating of equipment.
eg You probably would not feed a small 2,500 SF office building with 480V but you probably would a 50,000 SF building.
Anyone consider this before?
thanks,
bbaumer
I have designed both (480 and 208) in the past, but I never really gave your specific question much thought. I would say it had more to do with the equipment being fed and not the square footage of the space. Even with a small building, if there are a couple of heat pumps, air handling units, exhaust fans, blah blah blah then you'd probably better go with the higher voltage. It's a judgement call really.
If you had mostly 120v loads it wouldn't make much sense to go with 480.... other wise I think I'd prefer it.
I think you'd probably just have to decide on an individual basis.
An air conditioning load greater than 10 tons for a single unit seems to be one of the main things that triggers the need for a 480 service. That, and larger locations with primarily lighting loads.
It really depends on the needs of the customers building.
We have done a few large hotels, 4000 amp 208Y/120 services. Not much use for 277 or 480 there and transformers take up space they want to rent.
OTH I have done 200 amp 480Y/277 services for small industrial occupancies.
All machines, some lighting that can be 277 and the 120 loads can be served by a 30 kVA transformer.
Thanks for the replies. Trying to convince a client it makes sense to go to 480V on a particular project without having to do a bunch of analyses and estimates.
Some people simply don't want to own transformers. I have one customer who's building has three 5000 amp services, all at 208. They get all their manufacturing equipment made for 208, and order their A/C for 208.
The hotel that we've both worked at (Rt 1, Norwood) actually has two separate poco transfomers outside, one 208 and one 480, and obviously a separate set of indoor distribution for both systems. I thought that was a clever way around having multiple transformers inside the building , and not something I've seen anywhere else.
That was not one of the ones I was thinking of. :)
That one is kind of of weird, I think the next door neighbor owns the 13.8 distribution supplying the Hotel. So I think the Hotel has two feeders not two services.
I figured that. :) Plus, the hotel doesn't have a 4000 amp service to my knowledge. ;)
Interesting, I didn't know that. I remember the job foremen talking about NP&L being involved with a shutdown there so I wasn't sure if the transformers were services or owned by FMG. :confused:
I am not 100% sure but that ugly building at the back of the property has 13.8 distribution as I recall.
