Hello everyone,
I am gathering information for a power study on different UPS manufacturers and the one issue that many will list in their documentation is output current THD. Is there any figure, or reference value that states what the typical THD should be with 100% non-linear load, other than the lower the better? I understand what harmonics are and what causes them. And the way I see it, a UPS can control the input current and voltage harmonic (by way of the efficiency of the rectifier and input filter) and the output voltage harmonic (efficiency of the inverter), but the output current harmonic will be affected by the load equipment.
So, is there a good number to use as a reference?
