All the wire that I have is labeled THHN/THWN.
I never look at the fill for anything other than THHN.
Ok that's what I thought. Now if you use it in a wet loc. do you have to use the THWN colum, which is 75 degrees, for derating?
You can use the 90 degree chart for derating . This would be your maximum load current. OCP would be determined by type of load served .
