Jgkopp
- San Clemente
This is located within a residential backyard setting. What is to stop a child from opening up this disconnect cover (no tools needed) and then touching the live 240 volt electrical inside? In the video you can see how easy it is to open this cover. It's also about 3' high off the ground. I am just asking if this is up to code because I don't know.
We install a pull out type disconnect that requires considerable strength to remove the pull out and there is a plastic plate inside so one does not have access to the electrical if one just opens the front cover.
Thoughts?
Video:
https://youtu.be/7-KO3dGm0ZA
Thoughts?
Video:
