Howard Burger
- N of Anchrage, AK
Hey, folks. I think I have a solution to a condensation problem but I want input from you folks who have been around the block.
Problem: in the fall (like, now) and spring, when it?s in the low 50?s outside and we get all-night rains, my stove hood leaks onto the stove. It's a condensation problem ? I?ve got about 60% inside, and it?s 98% outside, so it?s not humidity going up the pipe that?s condensing. I've moved the pipe from straight up into the roof to up, 90 and then out through the attic (gradual downslope) to vent out the back of the house, and it still drips. And the straight up pipe is insulated.
I?m thinking my solution is to warm up the pipe (I?ve been leaving the fan on low and one burner on at night to keep the pipe warm, and it seems to be working). But is a better solution putting some thaw wire around the pipe, to be turned on when we get one of these fall/spring rains? I?m not sure thaw wire is designed for this, and back in '97 I discovered a fire when I worked up at Prudhoe Bay which was a thaw wire burning up visqueen and insulation near it. So, I don't entirely trust the stuff and of course, there is no smoke detector in the attic (yet). I would sure appreciate any feedback about my idea.
