wireman1
a company has a existing 2000 amp main distribution service which the utility has monitored for the highest load which was around 1500 amps . they also experienced spikes. the company is now putting a new section of switchgear which is rated at 3000 amps with a 3000 amp breaker the utility is not going to change out the transformer which they maintain or up grade the wiring from the secondary to the main breaker. they are going to put current limiters on the secondary side of the transformer and do a gfp test to set the tripe setting on the main breaker which is required by 230 -95 (c) is this acceptable with out upgrading the wiring from the secondary since the transformer is owned and maintained by the utility
