Mezani
- Washington
See the attached picture
My point was that we don't know that, yet. If that is true, I have already said I thought it would be compliant. If the covers are hinged and not easily removable, that changes the game.Since there is options to place covers out of the path of egress . . . .
...If the covers are hinged and not easily removable, that changes the game.
Why?
If the worker creates an obstacle, how is that the designers fault? If work is being done on the far left cubicle, then it is up to the worker to make sure the center doors are kept closed, just like they need to make sure their tool boxes are not obstacles.
As a design engineer, it is my responsibility to avoid issuing a design that could prevent the worker from having a safe work environment, a design that at the same time makes it difficult for the worker to render the work environment safe. Part of the problem is that the equipment is often selected long after my design is issued, and my role has ended. So if I issue a design that takes advantage of the "unobstructed path" option, and that has only one egress path from the working space, and that assumed the covers could be completely removed, and if the contractor buys equipment that has hinged doors, is this something that I could have prevented? Maybe. If I am being paid for construction administration services, and if I am sent the submittal for the equipment, and if I fail to notice the hinged covers, then yes, the responsibility does fall upon my shoulders. That is what I have to accept, when I sign and seal a design document.If the worker creates an obstacle, how is that the designers fault?
How am I going to keep the door shut in the section I am working on?
Remove it? Sure sometimes that is easy and when it is I tend to do so for my own convenience.
However many of them are designed in a way that makes removing the door very difficult or they have wiring on the door for meters etc.
..."unobstructed path" option....
Is this a storeroom of some kind? Was this an explosives manufacturing facility at some point? Those are seriously thick walls.
I am wondering if you commenters see something I can't. I see comments mentioning equipment and such. I cannot see a legend. Are y'all assuming what the room contains?
