ElectricAvenue
- Houston, TX, Harris CO
Hey there everyone I am new here,
I am an apprentice electrician working in Houston, I am also a 3rd year student at IEC. Last nights lesson in school kind of opened my eyes about some things on grounding and bonding. Currently this week I have been working on some 80-100 Ft Light poles at a junior high school football field. On top of the poles are a cage with gutters, and 1-2 panels feeding a set of 10-20 lights depending on the pole. Everything on the pole is completely full of rust, the panels are rusted, including the gutters. The wiring is so old that it's falling apart and at any given moment those wires can lose their insulation. Nothing is bonded anywhere on top of these poles. Coming out of the gutters are 12/2 SO cords feeding the light fixtures. The ground wires are cut back on both sides. The only ground that is installed is a 2/0 AWG wire that bonds to the base of the pole to apparently a ground rod though I have not seen this myself, only been told that there is one there. The poles are being fed with PVC conduits with no ground pulled in any of them. I brought this up to my contractor and his response was "We're getting paid to change ballasts and bulbs, not to ground an ungrounded system." I told him I didn't want to work on this because I didn't feel safe and I didn't want to be responsible for what could happen if some kid came in contact with these poles are the wrong time. I just wanted to know if it sounds to you like these poles should be worked on or not. I could possibly lose my job over this so I just wanted to make sure I at least wasn't wrong about it. After all my book does say that the earth is not an effective ground fault path and from the looks of it, the only thing that's grounded or bonded on this pole is the earth.
