Performed NEV test today. Everything tested okay until I came to an outdoor air compressor. The shielded flexible conduit comes out of the building across a fence into a disconnect and then the compressor. The compressor and disconnect switch tested fine but I found the fence to be unbonded. I thought this was strange since the feed goes right over the fence. And you must open the gate to get to the compressor. Lastly the ground is always damp in that area. So my question is, where can I read more about this in the NEC? Does this sound like a code violation? I'm guessing the fence should be bonded? Thanks
