Island receptacles 2020 code cycle
nizak
Would the code requirement be met if a receptacle was located at the end of the island and just inside an openable cabinet door?
It would be 10” below the work surface and 3” inside.
Thanks
Thanks
I don’t see how a receptacle in a cabinet behind a cabinet door could be looked at as one of the required receptacle outlets to satisfy 2020 nec 210.52(c)(2)(a) and (c)(2)(b) .
probably not, island receptacles are the worst when it comes to residential construction. i had an inspector make me change a single gang to a two gang to satisfy his needs. he even said, let the permit go into the next code cycle and you wont have to change anything. residential construction needs its own book in my opinion
