turls
New member
- United States
I recently installed a 25 kva xformer using it as an iso trans to take 240 to 120/240, deriving a neutral. (This is for a new sound system, which required iso ground receptacles as well, in a church.)
From the existing panel I fed the new xformer with two lines from a 2-pole 100 amp breaker. From the xformer I had the two lines and neutral feeding the new 100 amp panel. The ground came from a copper water pipe, came into the panel and landed it on the ground bar. The neutral was bonded to the same bar. I then took two #4 green with yellow tracer wires from the ground bar up to the isolated (insulated) ground bar.
Another jw had to install one more circuit at a later date, he called my boss saying I dont know what im doing, he then "unbonded" the neutral from ground, and took the ground electrode conductor and connected it straight to the iso ground bar and removed the jumpers connecting the iso ground to the solid ground bar. Now I have 15vac between the neutral and iso ground, and 3 vac between the sg and ig. Which way is correct?
