Shockedby277v
- Michigan
Anyone have a brief description and definition for it??
brian john said:Around here they are called dedicated Circuits. Two wire circuit with ground sometimes IG ground, ran to a single receptacle, though usually a duplex or power strip is in installed. Which would seem to negate the term.
Shockedby277v said:To feed isolated outlets for computers.
roger said:This would typically mean an Isolated Ground circuit. This would be a circuit with two EGC's, one will ground/bond the conductive surfaces such as the raceway and boxes, the other will be dedicated to the receptacle.
This involves the use of an Isolated ground receptacle or non-metallic raceways and boxes and a standard receptacle.
See 250.96(B), 406.2(D), and 640.7(C) (there are other references as well) for a little information on where they would be used.
Roger
Shockedby277v said:To make sure I get this straight, the IG will terminate at the service ground bus?? to make it officially isolated?? Sorry for so many questions, my prints are poor.
