In a 2 pole 3wire-fused-general duty-100amp-indoor-Saftey Shift With NO Nuetral with a mechanical {dirty} ground bar and a Isolated {clean} Ground conductor identified with yellow tracer terminated on the nuetral bus bar supplied by the manufacture. Is there any thing wrong with the termination here??? The green screw provided is not used and the bar is used just as splice point. The IG conductor is from a k-type, isolated XFMR were it is bonded with XO an d cold water pipe per code and the safety switch feeds a 6000 kva Symmetra UPS WITCH IN TURN FEEDS A "DEDICATED" LOAD CENTER...... IS THERE CODE THAT SAYS I CAN DO /OR NOT DO????PLEASE ADVISE thanx PLF.
[ May 12, 2003, 12:45 PM: Message edited by: pqpro ]
