wilbur101
I have a design for an isolated ground system. The building has a ground loop with ground rods. An additional ground rod is connected to the ground loop and then brought into the building (insulated wire) and connected to a panel. The panel is grounded to building steel, but the terminals for the isolated ground are isolated from the panel. The isolated ground is for I/O in a Delta V control panel. The Delta V panel is fed by a 120V ups ckt (hot, neutral + ground). The ground for the shields for the I/O cables are taken to the isolated ground panel mentioned above. Is there a problem running the isolated (insulated wire) ground conductor in metal conduit (insulated wire cannot be bonded to conduit due to design requirement)? Also, the conduit carrying the isolated ground wire is connected to the 120V UPS power conduit. The isolated ground is in conduit by itself for about 30 feet and then connects to the conduit system for the 120V UPS power and runs for about 70 feet to get to the delta v panel.
