bradlittle
How do you ground(bond) the raised cover if you install an isolated ground receptacle on/in it. we are required to bond the raised cover to the box/equipment ground with a regular receptacle, and the requirement isn't different for an isolated ground receptacle. the raised cover doesnt have a specific ground terminal, so how do we bond this? the only thought would be to use a ring terminal and bond to one of the two screws securing the receptacle to the cover. any thoughts? thanks!
{Moderator's Note: Edited to remove personal contact information. If you wish to contact this person directly, then start by sending a Private Message.}
[ February 21, 2005, 06:10 PM: Message edited by: charlie b ]
