mshields
- Boston, MA
Recently encountered a receptacle in an OR with a green dot on it; i.e. the symbol for Isolated Ground. The receptacle is wired to an Isolated Power panel. But certainly does not have isolated ground.
I thought someone, somewhere along the line had confused the two and that the green dot for Isolated Ground ought not to be on the device.
A google search revealed other applications where Isolated Power systems used receptacles with this same green dot on them.
Isn't that incorrect? Is there even a symbol for Isolated Power Receptacles? If so, what is it?
