I have an isolation transformer (240V:240/120V) for sound equipment in a performing arts center. Should I bond the isolated ground conductor to the ground system at the transformer or pass through the transformer and bond the isolated ground conductor at the service entrance panel's grounding system?
Also, Is it acceptable to size the isolated ground conductors as you would any other EGC? Thank you for your help.
Scott
Scott
