Caveat- I understand that there are different thoughts about the effectiveness of IG circuits, I'm more interested in getting a better understanding of IG because the client is asking me about installing some.
Scenario- This is all sound related. There is a 1,500 chair Ampitheater with stage that I do a lot of electrical work for. On stage there is a sub-panel that feeds various circuits for sound, lighting, and other misc props. The lighting guy was asking me about isolated ground circuits for the sound equipment because the sound guy was complaining that the lighting equipment was messing with the sound equipment.
The sub-panel is set up as you would expect. This is 208y 3-phase. The sub panel is not setup with a redundant ground. I don't do a lot of work related to IG. Questions I have:
1)Would I have to add a dedicated insulated ground wire all the way back to the G-N bonding point at the service?
2)If so does it have to be grouped with the feeders that supply this sub-panel?
3)Would that redundant ground wire have to be sized based off the breaker size that feeds the sub-panel? Or could the ground wire be smaller since it's only protecting the receptacles that the sound equipment is plugged into?
The electrical system is pretty large at this Ampitheater with a lot of sub-panels, which are fed by other sub-panels, etc. it might be challenging to get an IG insulated wire to this sub-panel.
I just wanted your thoughts before I meet with the sound guy this week.
Thanks!
Thanks!
