A facility has recently realized they have several operating rooms (OR's) that are each fed from one isolated power supply. (ie. a hospital grade isolated power supply with an ungrounded output).
If one of these power supplies lost input power, or if it went bad, that would leave an entire OR completely without power.
So I am considering adding another isolated power supply. I would use this supply to feed half the existing receptacles in each of 2 OR's.
Does anyone have any experience feeding one OR from 2 isolated supplies? Would the neutrals have to be bonded together? Would this create any issues for any of the OR equipment? What if two pieces of equipment were plugged into different supplies, but maybe they have a communication cable that creates a circuti between them? Does that cause any issues?
Finally, I had also considered moving some of the receptacles to a normal grounded supply. But I think that is out for the reasons above (two pieces of equipment could ground the ungrounded supply through a communication cable.)
Any other thoughts or caveats for designing isolated power supplies?
Steve
Steve
