fraymond
- Huntsville, Alabama
I am looking to "shield" a bank of 120VAC solid state relays. Currently the SSR's are in an enclosure along with some instrumentation amplifiers. The amps' sit on a shelf and the SSR's are below. My contention is I don't want an unqualified/non-arc flash wearing employee entering into the enclosure unless I can remove the potential from the SSR's (which means he has to be trained, suit up, and check if the potential has been removed). I was thinking an alternative is to barricade/isolate the SSR's by using a piece of phenolic or acrylic. Another thought is to set a non-metallic enclosure with door inside the existing enclosure and move the SSR's inside of it. What are your thoughts, concerns, etc. Thanks
