electricalperson
- massachusetts
recently ive worked on an isolation transformer at work. when i put my meter on the secondary i had 61 volts from each wire (hot and neutral) to ground and 120v L to N. the isolation transformer was feeding a faraday cage for plugs and a few lights inside. i called my boss and told him im getting this voltage and he said this is normal. the neutral wasnt grounded inside the transformer and i was a little confused..is this normal?
